  • Replies 24
Work on 1 ton of green wood = 2m3 of 8-10 inch cut and split
A lorry load will cost about £1400 at £55 a ton delivered
Which turns into about £5000 delivered
Hi
As a guide how many cubic metres of wood still in the round 3m lengths would you expect to get on an artic. Saying it fills up with wood before it fills up with weight.
Thanks
Why do you want to know that figure Bob?
Perhaps you want to know what a load will cost you.
You will pay tonnage for Hard and meterage for Soft (generally).
25 Tonne of Hard will give you 45 Tonnes average if split to 10" (250mm).
Does this help? :001_smile:
You mean once you saw hardwood up it gains nearly double the weight????
That's amazing
Not sure why you are all measuring cord wood in tonnes! Down hear it's measured in solid cubic meters 40% air. I get an artic self loader and it can carry 29 cubic meters of solid wood. So (bit complicated) if you add 40% for air that's the volume of stacked timber laid up in forest. Which is roughly 40m3 sat on the floor all in 2.3 m lengths. The lorry is pretty packed7f6cd89557183dd808deb384b695d374.jpg
Hope this helps
Sent from my C6903 using Tapatalk
I've just been offered an artic self loader of wood, but it doesn't have scales
They load it up to 28 cube .........
Most experienced drivers would know whats on there weight wise within a mile of leaving site. I dont understand the volume purchases, far to many variables. Everything I sell has a weight ticket unless its rough old logwood and then the values are discussed over a brew, some head shaking and the sound of sucking through teeth.
Bob
