Land Rover Defender 110 single or double cab tipper?
The single cab on the landy is pretty tight to say the least. You've got under seat storage and a bit behind the seats, but it's not a lot.
Bed space on a 110 double is pathetic. Ok for a bale of hay, but that's about it.
130 double cab is where I'd be looking.
  • Replies 23
Hi NJC only trouble with the 130 is the turning circle trouble is like 🛳🛳🛳🛳🛳🛳🛳🛳🛳🛳🛳⚓️⚓️⚓️⚓️⚓️⚓️Thanks Jon
Just fit a wider offset wheel and adjust the lock stops be surprised how much more you can get !
Not if you keep to sensible offsets like the seller steels etc if you put a ridiculous offset on it yes !
Like anything if you go silly expect things to break but going sensible things tend to work !
I think single cab 110 would hold a fair amount. By the time you get chipper or trailer on the back you will be getting there . . .
Hi TWIS even worse if you have wide tires on thanks John but I can see your point
