Well if it works then in works!! :thumbup1: Sounds a good way of doing things....
But I wouldn't have the patience myself :001_rolleyes:
It's what you're used to I guess. I get on much better with sharp hand tools rather than power tools.
  • 2 years later...
Had a lot of half finished type projects kicking around and so have focused and started to finish some of them.... I find Summer is the best season for selling and getting your name out there. Nothing new design wise but some cracking wood - elm (from Big J on here - if you want elm PM him!) and some walnut milled a couple of years ago.
Done a vid on sanding and making one of these tables which I'll edit and put up soon.... have made a few more things as well which I'll also take some pics of.
:biggrin:
Some cracking figured wood there, what do you finish them with,Danish oil ,French polish or do you just wax them ?
Inside stuff danish oil or walnut oil - both cheap, easy to apply, no skin to scratch... I don't tend to use much wax anymore but you can wax over both these oils if someone requested it....
Solid sweet chestnut bench - there was shake through this so no good for planking. A lot of sanding involved but was sold for £650-00. Made using the mini mill. Only 4 cuts used to make the whole thing....
That is lovely, worth every penny:thumbup1:
