I find I can sell beams to the oak framers round here for £16 to £20 per cube but it's rare I have good enough oak to produce the quality they're after.....
  • 4 weeks later...
Had play with my Small Log Mill today.
I haven’t milled anything before so I thought id practice on a few bits of larch and made this rough bench.
Cracked the LCD on my camera so pic's are'nt too good.
did you use a chain saw to carve out the holes for youre joints? have you wedged (technical term!) the joint on the outside?
Yes and kind of wedged.
I cut the bench ends first, placed that level on a log, offered up the legs penciled round them and then cut the holes.
Then drilled a 15mm hole at each end and whitteled an offcut to fit and tapped it in.
