Started to tip the back of my transit this morning and after going up a couple of inches it just stopped and won't do anything now. Interestingly an led light on the back that I had never worked suddenly started flashing at the same time and I can't turn that off now without taking a fuse out.
Can anyone point me in the right direction?
Cheers
From my extremely limited knowledge! While looking into converting mine I found that some manufacturers seem to have a 'mega' fuse near the battery and a smaller fuse on the wiring to the control. Check both of these then that's me beat!
give tipper its own earth to test, jump lead from battery to earth on tipper, disconnect one on truck first. if that works then much cleaning up of earth points and then seal up to keep water out in order.
Turned out to be a dodgy wire at the control box in the cab.
Obviously an easy and thankfully cheap fix but took a while to find.
Cheers for all the replies...... I'll Know where to look next time it stops working!
