I keep reading hazel is too useful for firewood and I know well managed coppiced hazel has a myriad of uses but can anything useful be done with hazel stems that are 10+ cm DBH and often a bit misshapen? Apart from firewood or charcoal that is.
  • Replies 22
I tried making a hurdle out of wonky Hazel from our wonky Hazel coppice.... I found that clefting wonky Hazel is pretty difficult.
My hurdle reached an awe inspiring height of 1ft 8inches before I gave up.
cheers, Steve
We keep all the straight over stood hazel for hedge laying stakes anything over about 60 to 75 mm I cleave, point and store undercover. If you get good at cleaving you can split some of it into broches etc for thatching also greenwood furniture, hope this helps.😀
I've cleaved a few thick stems but don't have a huge use for them. I do have some hedges to lay but being Devon hedgebanks will not need many stakes.
How long does the hazel last in the ground? I a need for fencing takes but don't think hazel would last long?
uses for hazel can be quite a few when you dig up older records, just a few i've found on the net are, wattle and daub, thatch brooches, runner bean poles, net stakes, water divining sticks, hurdles and furniture, pea sticks , friction firelighting, basketry, walking sticks and shepherds crooks.
Yep, they are great for making runner bean poles/ wig wam structures, we also use them for training our Sweet Peas. It's not a durable wood so expect to get a couple years use in an outdoor environment. cheers, steve
I've used a fair bit of hazel for bean poles etc but they're not going to be that thick, rather what I'd call normal coppice size (less than 10 years old).
I have made a few good walking sticks from shoots growing up from large limbs, part of the old limb makes a decent round handle.
But I can't think what would have been done with stuff that's logs size, well over 40 years old, apart from logs. I suppose in the days when coppice was worked then it wouldn't have been left so long to grow too large.
Has anyone turned it? A few pieces I've split have a very good grain.
wooden bowls for eating from were carved in medieval times and bodgers would have undoubtedly used the larger bits but i couldn't say what for.
split hazel can be used for carving love spoons or just a normal spoon and probably was used to turn spindle for holding threads in the old days.
sadly most of the uses of hazel have been usurped by manmade materials.
The problem is the thicker stuff tends to be pretty gnarly and twisted so isn't great for much except firewood. Makes a decent enough spoon but thats not gonna make a dent if you've got loads of the stuff. the larger straight stuff can be cleft into thatching spars or sold cut to length to a spar maker. But we're talking pence here.
Cut it up for firewood. Saves you getting a log splitter as it comes in a nice variety of convenient to burn sizes!
Read more
