ford fiesta flat battery
simonm
I've got an 09 plate ford fiesta van that I use for quoting, I put a new battery on around 6 months ago, when the van has being stood for a while the battery is as flat as a fart and won't start, its as though something is draining the power! Any ideas?
Hi SIMONM get the battery tested and get amp meter to test Power drain When the car parked up thanks Jon
Hi
You may have an earth on your wiring or if the battery is dirty tracking down the side of the battery, although if its stood for a while it will have self discharged via internal resistance.
Or it could also be the alarm draining the battery if that was on.
If you leave your vehicle for a long time you could try a CTek charger as they will keep it topped up & you dont have to remove a cable to charge.
N
