2 screws in the wall about 100mm apart, a piece of string tied to one screw with a loop on the other end, pass the string through the handle of the saw place loop over 2nd screw. The saw then hangs vertically down the wall from the string through the handle. Neat storage and only needs 2 screws ( and rawplugs) and a bit of string
How well does this stop Huskies leaking their oil and mix? I've never found the best orientation to store them.
BTW rawlplugs are old hat, use multi monty direct screws.
  • Replies 34
Sorry Roy, missed your post.
They're the things you slot through to lock them a certain height.
I don't think anything more complex than a shelf is needed for storage.
Security wise I've seen a heavy duty chain through all the handles.
Cheers Mick
Can't say on that, sorry, I only have a stihl ms180. No leaks from that though.... I knew there was a reason Stihl are mightier than Husqavarna :001_tt2:
Rawplugs maybe old hat, agreed. They are cheap and work for this purpose however.
