husqvarna t540xp
hi,
When the saw is running and just after, oil can be seen running out from behind the plastic shield between the bar and the engine. Oil is even coming out between the same shield and the engine on top of the saw (see photos).
Also when not running there is a lot of oil on the bottom/ bench. there is also a missing bolt can this have something to do with it? Does anyone know what could be wrong with it oil pump?
Also i tried taking the clutch off by putting rope in piston but no luck is there another way of getting cluth off?
thanks
  • Replies 31
Have a look at the tank at the bottom of the bar where the chain runs around. Friend of mines chain had chewed a hole through the tank
Not sure what the problem you have is caused by there but on a side note and a heads up it looks like your chain has hit the crank case and has taken a little Nick out just next to where the serial number is. Keep an eye on that as mine had cut all the way through before I'd noticed leaving a hole where the oil definitely will come out which I had to fill. Are you still using the original bar? Also pull cord should do the trick getting the clutch off I had mine off that way
Filled it with jb weld it seems to have done the trick. Only reason I ask about bar is because it was when the original bar on mine decide to come apart and fly the chain off that's when I had the problem
I remove my clutch on the 540 with a hammer and screwdriver. On the outer face of the clutch are two slots. Put the slotted screwdriver into a slot and shock it off in a clockwise direction with the hammer, having rotated it to max compression. A couple of good firm knocks and off it'll come. Not sure if others do the same, but that was the way it was taught on cs 30, and it's worked fine for me ever since. Remember - it's a left hand thread!
