Hey folks I have a small Honda 4 stroke ohv engined power washer which is meant to produce 2500psi. I didn't buy it new but it looks like its had very little use. The engine and pump are in very good condition with no leaks, but there is very little pressure. I can hold my hand over the lance nozzle when on full power which I don't think I should be able to do as 2500psi should strip my skin off. It has a plastic K'archer lance and hose with one of those orbiting turbo lance ends. The hose is also plastic and has quite a small internal diameter. Could the lance and hose be the problem? Thanks
ok some simple stuff have you got the engine revving at the top ? is the pressure the same when you turn the engine off and you just press the trigger ? sounds like the pump to me though ! it could be the lance best way to test it is with another hose first and then another lance
Relief valve stuck open or seal broken up perhaps.
Have you a reasonable flow but with little pressure?
There should be a filter in the system somewhere so worth checking.
Yup my guess would be that the unloader valve is either stuck open or wound right open there should be a plastic handle that you screw in for higher pressure and out for less
for all the cost i would send the pump to somebody who does these, get tested and go from there.
how does the engine run? does it sound like its running good?
i also have a honda engine powered pressure washer, its got bags of pressure but its a good hose and lance from pressure washer company.
pump fault would be a likely suspect
The small diameter of the hose could be causing the pressure relief valve to dump. If it's been doing this for a while it may have damaged the valve. Also if it's a rotory lance for a bigger machine the jet will be too big. Or it could be a combo of all above
Are you 100% sure its a Honda or is it a generic chinese one. These work well but need loads of water , pressure fed to it. If you know you have plenty of water and it is a chinese, then change the pump is the best bet, about £60 and 20 mins job
