  • Replies 43
So sorry to hear that and this relentless thieving is soul destroying.
Just who is doing it? Is it gypos, Eastern Europeans, natives finding cars too hard to steal these days so going for other kit?
Something else altogether??
dosant matter were yr yard is they can all be hit , if you take the wheel of they will come with a hiab ,youve got to start thinking like then imo. to have any chance to against them,
What, go and nick someone else's chipper to replace yours?
is there a battery powered tracker available (I'm thinking long life batteries) that could be concealed inside the box section frame of a chipper, even burn an opening, pop the tracker inside on some araldite etc and weld a patch over grind flush and paint.Suppose it depends if a tracker emits through steel plate, but surely a possibility, even with a better location for concealing it, fuel tank?
they sorted that yrs ago im afraid,they take the tracker off ,put it on a truck going in the opposite direction, :thumbdown:,its all do with orgernised crime imo,thats why so little gets found
that's why I said could it be hidden - even if it means cutting and welding the box section chassis.
Shade 11600 Live Vehicle/Asset Tracker - Eyetek Surveillance
I haven't researched it in any detail and obviously if it were welded in somewhere there may be difficulty charging the batteries, maybe the fuel tank is an option.
You can get gadgets to locate trackers so where ever they are they will be found and removed.
oh - there must be some way
hole in the ground breezeblock retaining wall big enough for chipper, grinder etc, steel plates over hole. Rusty old loader tractor in yard. Cover steel plates concealing chipper hole with woodchip. In morning scrape off wood chip, move plates and lift out chipper.
