  • Replies 127
Currently:
SRM-222ES
SRM-300TES (Loop handle)
CLS-4600 (discontinued clearing saw)
HC-2300 (predecessor to HC-331ES)
HC-331ES
HCA-2400 (predecessor to HCA-265ES
HCR-1500
PB-255
CS-360TES
CS-600 (predecessor to 610 and 620)
CS-8002
Will definately be buying within 12 months:
CS-2510TES
CS-620SX (x2)
CS-390ESX
PB-770
:thumbup:
Edited by TimberCutterDartmoor
Currently:
SRM-222ES
HC-331ES
HCR-1500
PB-255
CS-360TES
CS-8002
CS-2510TES
CS-620SX (x2)
CS-390ESX
PB-770
:thumbup:
Is there anything you don't use? :biggrin:
Mainly hedge cutters at the moment:
HC331ES
PAS265 (multi-tool)
May not be as robust as their saws but probably no worse than Stihl or Husqvarna hedgecutters that i've owed.
HC331 has needed a new ignition module plus loses blade bolts.
Pas265 has needed a new flexi drive and both the throttle trigger and dead-mans trigger replaced.
Excellent information, thanks for taking the time out chaps.:thumbup1:
Looks very promising, will have to have another chat with the Echo rep and see what we can do.
Spares are something I want to have a decent stock of hence possibly narrowing the range down and just going for the more popular machines.
Please keep the info coming.
Cheers
Mark
CS8002 - Used on a daily basis, incredibly reliable.
HC341ES - Erratic use either have loads of hedges all at once or none for months. Incredibly reliable, really good finish but struggles with thicker material/neglected hedges so I also have a HS86R which is unreliable & leaves a poor finish & a HS246 attachment for my 026 which will go through anything but leaves a poor finish. Once the thicker stuff is cut with whichever Stihl hedgetrimmer I use I finish off with the Echo.
PB750 - Only comes out for the bigger jobs as a hand held blower is normally sufficient, always reliable, tons of power have to be careful not to lift poorly laid slabs or tarmac with it.
Never needed parts for any of them.
