Bought my self an iveco daily last week bought it back to ireland yesterday I've 2 warning lights on one the fuel filter I cheeked filter for water but was all good then the other light is injectors or so it looks
Also got home this eve I could smell diesel looked under it there was a pool of diesel checked the filter but that was all dry can any one help me please
  • Replies 23
Injector light can come on if someone has played about in fuse/relay box and need resetting,but like mine that is on because I have a bit of air lock in system and has drove me round the bend ,Hpi system has to be spot on and no leaks.
Ste
Take it to an Iveco main dealer.
It may cost to have them plug it in and diagnose but it could save you a fortune in the long run.
They will give you a quoted price before they start.
On a daily basis they deal with these issues - there is nowhere else to go IMO.
:001_smile:
Iveco electrics are a pain in the backside - my airbag warning light has come on (and it doesn't have airbags)...
Same here , wizz the fuse out half way down on the left side but you need to find another feed for radio , again another con to get money out of you at the dealership.
Ste
Sometime the dealership route is a wise choice - they will diagnose any issue you have with electrics faster then anyone.
You can always go elsewhere and get the work done, but surely you are better off solving the issues there and then, wasting no more time and getting back to work.
Other views will differ.
Start with the fuse box. A lot of idiots put fuses in the wrong holders, check the guide,
Then get under and check the fuel lines..... Any air in the system will bring up an injector light, also pull the positive and neg off leave for a while then touch the cables together to fully flatten the system. Not the battery, the cables.
Iveco are notorious for wiring issues.... Still a great van......
