  • Replies 103
jam a pry bar in the catch and it snaps the lock. Its a 5 second job
Are the Brian James ones as bad?
Mine has an alko hitch on it I think would it be a good idea to change it or add more security?
Also is it when attached to vehicle or when stood on its own or both?
no.they have a barrel lock and a ball that you push up inside the coupling when its unhitched. You have to drill it out first to steal it a pry bar will do nothing
Fit an indespension triple lock if you want to be safe. They have a barrel lock, with a spring behind it. drills dont like springs, and when I had my trailer nicked with the key and I recovered it, I had to drill the lock so I could hitch it back up. An hour later and several snapped drills, job done!!
If I was going to steal a trailer, one without a barrel lock would get my attention!!
Hi DAN we block them in with other kit helps slow them up thanks Jon
Here you go Jon clock this for a trailer . My mate popped in today with his triaxle IW with a crane fitted. He has just got it and wonders how he managed without one.
Edited by aspenarb
