Question
Hello
I'm hoping somebody might be able to help me
We bought a house at the start of the year and it has a huge copper beech at the front
Before we purchased the house, we were told one had to be removed from the back and a neighbour also had one removed due to disease
We are waiting for planning permission so not currently living in the house
We went to see the house today and notices there are three seperate breakouts of fungus at the base of the tree
Can anyone identify the fungus? And is it terminal for the tree? The tree has a TPO. Do we have to go through planning to have it removed?
We are on an estate and a couple have fallen down....I'm worried with winter approaching
Many thanks :)
Ps I've attached a picture, you can just seen another of the breakouts to the left hand side
  • Answers 28
Top Posters For This Question
  • 0
Thank you
A quick search on Dr Google says it doesn't look good for my tree :(
This is a picture of the other side of the tree with the breakouts. We thought they looked a bit different to the third (larger) one
Thank you again
  • 0
Agreed it is Meripilus giganteus, and traditional thinking is that on beech a fell is the only sensible option; however with more current thinking, if you are keen to retain the tree then there is more to it than "beech + merip = fell". So don't call it a gonna too soon...
  • 0
I agree Sloth - not an immediate terminal case, *but* those fruiting bodies are very tight into the stem and a reasonable size so the decay in affected roots may be extensive.
In truth, the only real way to tell will be a root excavation job at various points looking to the underneath of the root for decay extent - or investigation by TreeRadar which is amazingly expensive and good luck finding a contractor in the UK. With either method you can make a more informed decision.
  • 0
Out of interest with this sort of infestation if you end up felling the tree...
is the timber worth doing anything with other than burning?
what is it safe to replant with?
  • 0
Third option is a SIA. I assisted on one with Paul Muir of Treework Environmental Practice last year and almost certainly would have condemned the tree prior to the test.
