I've seen loads of people with the road signs that go on cones, any idea where I can buy some ready made, or do I need to get some strapping and some rivets and do it myself. Also I hear they're illegal, is this because they are light, cheap and efficient?
Don't bother mate, i had some and the black plastic sections break off which slide over the cone. The also tend to get smacked about and blown around.
The ones we supply come complete with a prefitted bracket which slides into the cone, so no alterations need to be done. The bracket is long enough to go down far enough into the cone to keep it in place. (I've never heard of them being illegal).
They come in various options:
Man at work and road narrowing triangles 750mm
Circular directional arrows 750mm
Rectangular Pedestrian arrows 600mm x 450mm
If you need any further info, let me know.
They just don't last being thrown around in our game though i found. I wouldn't buy any but see if you can aquire 1 or 2 to try out for a while.
We've got one that I found. I love the idea of it but you need an extra cone so the benifits aren't as good as they first seem. We also seem to have a cone shortage at the moment so don't use it much..
the plastic rivets always snap too and you end up having to redrill them and put pullcord or new string through. also, as has been said at least two cones are needed if it's at all windy, otherwise you spend half the job watching them blow over or down the road.
the problem with the road signs that go on road cones do not stand up to windy weather well at all , however if you are working on a site for a short period of time then they are quite good to be honest , i have seen the local council using them and they seem to get on with them . i tend to use the fold up road signs with added balest bags to stop them blowing away .
oh and as for the roas signs that go over cones they are not meant to be used on any road with a speed limmit of more than 30mph . oh and are not intended to be used over night either as they do not meet reflective standards.
hope this helps mate
