Does anyone burn wood chips on a wood burning stove?
I've got access to some w30 g30 chip and thinking I might give it a try to see if a shovel full will keep the fire smouldering over night on a low burn?
Or whether it would just smother the fire out?
Not really recommend.
You get a build of of gases and when they ignite cause an explosion, usually blowing your stove doors off.
A large wood chip boiler slumbers by feeding a small amount of chip every 1/2 hour or so. No fans running but a big boiler and small amount of chip. Normally a small amount of smoke is seen from the flue when in slumber mode so some natural draught is occurring. I suspect some air flow would be needed otherwise you could have a situation described by the briquette seller. Always having a flame to burn off the gases is safest.
Oh right! Maybe I'll give that a miss.
No, give it a go. You shouldn't believe everything you read on the internet!:lol:
If you have no draught and no flame the wood gases will be driven off by the heat then if a flame appears you will get an explosion using whatever oxygen is left in the boiler/stove/flue. The wood boiler at the Eden project blew its stack off amongst other things and was offline for a considerable time.
In the early days an inexperienced operator relit our boiler and fed too much chip in, smothered the flame and when a flame appeared that lit the gases there was a damaging explosion.
This is fact so be careful.
Do not totally starve the fire of air and maintain a flame is the safe way.
