Anyone between Taunton and Corby run a 12 ton+ beavertail?
  • Replies 21
I've just bought a smallish 5ton lorry in Corby, need it bringing to Taunton, ( needs some work on the brakes). Anyone capable? Cheers
Hi john got anyone yet mate I'm sure eggs will no thanks Jon
GreenMech run a wagon and drag, both of which have either beaver or ramps. But I'm pretty sure you would be better off taking to a Spec-lift equipped outfit like Crouch's or another HGV recovery outfit.
Not sure the tyres would be up to going on a spec lift, it's 1961 and on the original rubber! Not been on Tarmac in 6 years
There are HGV recovery firms with a sort of low loader with sliding axles to recover stuff if spec lift is too risky.
