RealEstate
Which Silky saw / pole lopper?
I need to clear some wires running through trees about 20ft up.
Think I need a silky-type pole saw for the larger limbs with a rope-operated secateurs to cut the smaller stuff that's too bouncy to saw; hopefully one tool with both attachments.
Any suggestions gratefully received.
TIA :001_smile:
Edited by RealEstate
Share this post
Link to post
TIA :001_smile:
Stein do a very reasonable pole set with pruners and saw blade. Check F R Jones
Share this post
Link to post
FR Jones say Steiner kit is interchangeable with Jameson.
Think I'm gonna get the following Stein kit:
Stein Pole kit 2 (pruner double pulley & rope, 2x6ft poles)
Extra 6ft pole
Saw head + 390mm blade
Total £164.05 ex vat
Sound sensible?
Share this post
Link to post
Extra 6ft pole
Sound sensible?
That's what I have. Good kit. Jameson kit fits perfectly, Stein have basically copied it exactly.
I have the big shot equivalent too but not really used it much.
Share this post
Link to post
Got my Stein kit as above from FR Jones - very good service.
Cleared about 400yds of phone line, worked a treat. :thumbup1:
With 3x6ft poles can reach to 20ft, if a bit wobbly. Once it's on the branch no problem sawing or pruning. Both saw and pruner (secateurs) are essential. Pruners good for 2" brush and saw whips through branches 3"-4" maybe more.
One point, I managed to avoid getting the saw trapped in a partially cut branch, but imagine it could happen :sad:
Since one can't do an undercut, is there a technique to ensure that doesn't happen?
Overall, good kit and good advice - thanks :thumbup:
Share this post
Link to post
Nice, up to 3 poles it works a treat it's when you got 4 poles and your at the top of A frames to get a two foot whip that's just sticking out but it's really anoying you. It gets pretty wobbly then :biggrin:
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
