Best way to heat the swimming Pool thanks
mendiplogs
  • Replies 35
Solar thermal tubes are excellent, but you will need a lot. Spending extra money on the pool cover, reduces dramatically the amount of heating required. I reckon a heat pump and large wood burner (specially made for heating pools) would make a good combination.... if you have a supply of cheap wood.
Hi mike sounds good wood mate would biomass do the job as I will let my mate no thanks Jon
Not sure about biomass but I remember looking at Klover woodburning pool heaters. Air source heat pumps are relatively cheap and you can get specialist swimming pool ones that are very simple to install. They can be noisy though, so position has to be given some thought. I think wood is the best option if your mate has a good supply and 'Woodworks' is right about solar tubes.... perhaps a combination of the two could be a really good system. I would also buy a good cover and I think you can get special solar heating covers, which must be worth investigating.
