as said above wounderd everyone's view on this and if you would change or add anything. Thinking of treating myself to arb pro ld1 bollard and harken winch .3x shizl spider sling 14mm. 1 dmm large rigging hub. Dmm impact block large. 3x rock exotica steel crabs. 1x pinto rig. 1x spiderleg balancer. English braids 20mm x 50 m rigging rope .
jay :001_smile:
  • Replies 21
There was a member who brought one of the Arb pro bollards and the only comment he left was it could not be used for ropes bigger than 14mm ,not sure what happened with that though so I would check that out before committing, personally would go down the GRCS as its tried and tested and lots of feed back.
ahh sh*t that's no good 14mm:thumbdown:
Don't quote me on though .... I did ring up one of the UK suppliers with interest of buying one and was told to ring back and speak to some one else in the mean while a cheap Hobbs style block popped up so never got to find out its full spec.
I'd maybe go GRCS , 16mm , dmm pulley & isc steel krabs .. The 20mm rope gets a pain to haul about & the 16mm will do for nearly every big work anyway . I've got rigging ropes 12mm-14.16,20mm , & the 20 doesn't come out much ..
Had the grcs 5 years now great piece of kit
Just to make you aware Arbormonkey, we launched a promo on all Arbpro products @ the Arbshow and through our newsletter. I've asked for confirmation but I believe as MattyF says the max diameter is 16mm but I'll let you know once confirmed:thumbup1:
