LED trailer lights.
skyhuck
  • Replies 36
So if I just change the tail lights on my Ifor for LED ones, will they work ok with the original marker lights and number plate light being as they are on the same circuit.
I can find LED marker lights but I can't find them for the numberplate and I would rather just change the lot.
Kev.
Kev.
"Bolt on bits" at Birkenshaw, Bradford in my link higher up the thread does everything you can think of Kev, I,ve just bought some side markers, i think they were about £3.50 each.
...and yes to your question :001_smile:
Thanks, Dean and Matt.
Got to be worth doing, I had to open up a tail light yesterday morn, ok it only took a minute to give the contact a scrape with the screwdriver and pop the bulb back in but it's a ruddy pest not knowing if it's going to continue working.
Regards, Kev
It's worth spending the bit extra and going dual voltage. You never know when you may need to put the trailer behind a truck and you don't have the luxury with led lamps of taking off a lens to quickly swap bulbs.
Bob
