Ive been running on 225/75R16 for about 4 years which was the size fitted to mine when I bought it.
The last set of tyres I fitted before these were 225/85R16.
The difference between the two is the wall height, in other words one tyre is much taller than the other, by roughly 3".
So I did some calculations for the 20k miles that I have done on the 225/75R16's which have a smaller circumference than the 85's.
Circumference
75 = 2.23m
85 = 2.48m
Revolutions per mile
75 = 721
85 = 648
difference per mile = 73 revs
If I have my calculations right, that means that over the 20k mile i have done on the smaller tyres, they have cost me 93.75 gallon of fuel more.
I also would have travelled a further 2250 mile
  • Replies 21
It's not as bad as you think.:biggrin:
The theoretical circumference of your 225/75R16 is 2.34 meters.:001_rolleyes:
So you would only have done an extra 1210 miles.:thumbup1:
The change in the gearing would have an effect on the reaction to the throttle position. A faster running engine under a lower load uses less fuel than a slower one under a higher load. The tyre difference is unlikely to have made as much of a difference as you think.
Also the 10% difference in side wall height would not equal 3".
A 225 / 75 has a side wall of 168.75mm
The 225 / 85 has a side wall of 191.25mm
Thats just 22.5mm per side wall.
Thats 45mm or less than 2" total height difference.
Edited by Justme
