What flavour oil can you use in Honda engines?
mowandgo
I have two Honda mowers. I have been told to only use genuine honda oil. Iam not sure why any branded quality semi/fully synthetic SAE 30 would hurt. Also you can only buy it in 600ml, far more economical to buy in 5l I would have thought.
JD do the same. Bloke come in to there dealership well I was waiting and paid £67 for 5 litres I nearly fell over
Hi
I have used 5W-30 synthetic oil in a number of small engines for several years.
Honda GX160 * 2 in old mower & a small cultivator, oldest are a 15HP Briggs & Stratton circa 1996 & Tecumseh 4.0Hp 1999 both run fine.
I think the manuals recommend a grade is 10W-30, 5W-30 just flows a bit better when its cold & 0W-30 better still.
The important thing is to change it because there are no oil filters, I try & change oil on mowers annually before storing for the winter, but often our grass continues to grow!
N
& I buy 5 litres at a time, much more economical.
Also the engines dont really use any oil, once filled the level barely drops over a year of fairly frequent use
N
Edited by NFG
