Files.
thetoolnut
  • Replies 25
I had to use a 5.2mm file on a .325 chain as I didn't have any correct files.... I quite like it, it chips really well, carried on using it for all of the chain, think I might keep doing from now on on all my chains...
ian
I occasionally use a larger size file to clean the gullet out on half or more worn chain in the workshop but hadn't considered using a larger file routinely when a chain is worn but it makes sense on thinking about it.
I am working through a load of Oregon files I bought and I think they are crap as they don't last at all in my experience, the stihl files I think are brilliant. Considering just buying these in future anybody use valorbe? Are they any good? The one in my bar dressing tool seems to last and last.
They used to recommend a smaller file on a worn chain ,( because the cutters slope away from the cutting edge) , to prevent you filling into the tie strap.
Surly it all depends how high or low the file is held. If you use a plate type file guide the hook angle should be the same whatever file size you use. If the file is too large a diameter it will cut into the tie strap.
Exactly:thumbup1:
But if your filling freehand the file will sit in the centre of the previous groove , giving more hook as the O.P suggested.
ian
I do this as it sorts damaged teeth quicker if I've been cutting stumps really low or gritty wood, also found Stijl files to last a lot longer than Oregon ones
