best saw for milling
Wood Troll
Which saw do I go for? I'm looking at getting a bigger Alaskan mill to take a 3 foot bar. Which saw do I get? I'm told the MS880 is unreliable and too much of a monster and the MS661 is over complicated when it goes wrong. I've been recommended the Husky 395, anyone use one of these?
Edited by Wood Troll
grammer
I milled some 3ft beech The other week and I used my 070. I would not of wanted to cut it with anything smaller ie a 660. More poke the better. It was hard going!!
The other week I did some 42" oak and dragged out the 090 and again I wouldn't of wanted for anything smaller.
I do recall a member having issues with his 880 with the bearings melting and I went along and finished off for him
Get the biggest saw available if 3ft will be a regular occurrence
Edited by Big Beech
For a 3ft bar you definitely want over 100cc or it will be very slow going.
Do you want new or old? If new, the MS880 is probably the best option (some people like the Husqvarna 3120 but it less popular for this in general).
If old, the 070 and 076 are good options - good parts availability. The 084 has some obsolete parts and I wouldn't go for an 090 unless you want to go for a bigger mill as you get very little increase in cutting speed on 3ft but it is a lot more thirsty.
The MS660 is excellent for up to 18" width (25" bar) - not noticeably slower cutting and a lot more economical on fuel. You can always break down the log with the big saw and bar, then swap over for taking boards.
Alec
whoever told you the 880 was unreliable was chatting tripe. Its the only saw i would consider for large milling, bar none. Mine has been used since 1997 for tonnes of milling and heaps of tree surgery, and until last year nothing went wrong at all. Last year i had to have a carb kit and this year some new clutch springs. The 3120 is not built for it IMO.
