Ok on diesel, I buy them buy the bag and fit them on everything, even the telehandler.
They have a stepped inlet pipe so you just trim it off to go to the next size of pipe. They are worth fitting because if something conks out you can eliminate the fuel at a glance. Worth noting they are directional.
got a bag full me sen :thumbup1:
Run them on everything, they're only a quid or so each, protect the main filter from clogging between service intervals and replaceable in minutes.
Edit: also if the tanks full of rubbish and intermittently stopping flow, you can see
Thats me sold then. So on the chipper cut them into the line before the metal inline filter which itself is before the main filter?
Why is it that machines and tools only throw their toys out when there is no time to fix them?
Thanks to all once again.
Dave
Dave
On the chippers I put them in the rubber line that runs from the tank to the electric fuel pump , that way you are keeping the crud out of everything.
Those packs of 25 used to come from Maces but they went pop last week :001_huh: similar things on ebay. Inline Fuel Filter - Large X 20 Diesel, Veg Oil - Clear Plastic Red Mesh | eBay
