Installing some stock fencing this week, unrolling the barbed wire with a bar through the middle and hands either side and thinking God this is heavy and don't fall over!! There's got to be a better way to do this?? Has anyone made a barbed wire roller on here? Can't be that hard to make?
I used a punch bar that poked in a hole on the side of my tractor loader, with a circular disk of plywood to stop snags on the inside. Providing you drove in a straight line the reel stayed on the bar. This was using the wooden frames reels not the metal wire frame type.
There used to be a wheel barrow chassis for carrying and un-reeling electric fence wire, perhaps this would help but you would have to allow the wire out between your legs as you walked along.......Mmmmm!!
codlasher
codlasher
Like your thinking an old wheel barrow?
I stick a bar through the reel then stick it in one of the holes where the canopy bars are meant to go on a landrover pickup- can unroll 200meters of barb in about a minute!
Otherwise 2 of you one on each side of the bar makes it sooo much easier but I used to do it on my own a lot using your method and always felt like I had biceps like popeye by the time I got to the end- worst was when it was unreeling and the barbs snagged on your jumper- ripped many jumpers/skin in this fashion!
