Nicely done, as usual.
Seems like you use a half-hitch with timber hitch with figure-8 stopper knot. Is that so. Is this stronger, easier to untie than HH with running bowline? Just personal preference? Another reason? Thanks.
Also, In another video, you were removing large limbs with a half-hitch with a choked line by way of a carabiner. Curious if you are just using a standard steel double lock 'biner, or something else, or if I just wasn't seeing it accurately. Most people would be concerned about cross-spine loading. What do you have going on there? Clearly it worked. Thanks.
Edited by SouthSoundTree
add'l question
  • Replies 30
thats a contentious issue that one. i rig the same for small to medium sized lumps. its not text book, but IMO most of the loading is in the half hitch......the speed and ease to tie, and for the groundies to untie makes it acceptable for me personally
yep, same as
In Part 2 @ 2:00 the limb seemed to swing around too much for comfort.
Shouldn't the rigging line be attached to the limb near the top or the bottom, to avoid the balance-point uncertainty? Hope you understand my point.
SStree, I dont worry about cross loading no, not if its set correctly....although I stopped sing Karabiners in videos for fear of the technique being misunderstood.
Morten, the rope was positioned to guide the rope off the stump, and as you can see it popped off nicely. I used the ground footage (and not the headcam) for that clip to add a little drama, because in truth the log was nowhere near me, so just an optical illusion really. Steve actually initiated the collision with the other spars because he didn't want the log to wrap itself around the trunk had he let it run.
