  • Replies 28
You can but it's not advisable, especially if it's under a lot of strain, they are cheap as anything and most bearing shops should stock them.
But not in a bank holiday Sunday, I was changing my belts and needed to remove the pulls.
I can :)
If you do re use it like Johny said make sure it fits back exactly right, and get it changed soon as poss.
Put it under the grill hodge,it a a TW cheese melts! Sorry couldn't resist.
I did the same to a rayco grinder about 4 yrs ago,re fit it and do it up as normal and it should be fine,the taper lock will still work.
When I did my bearing I couldn't work out how to take the taper lock off so I rang the timberwolf technical line, they said nothing about having to get a new one when refitting?!
In the past I have always fitted a new one, however I was not expecting to be removing this:( anyway I have sorted it and she runs sweet as. I will get a new one sent on Tuesday.
Thanks for all your input lads, yes even you Ian.:)
