Going off topic a little a friend of mine has a big yard under a set of hv cables he changes the battery's in all the machines every 6 months because the lines drain them apparently :confused1:
:laugh1: it doesn't
I find your comment a bit negative CJM.
You should try and be more positive.
I find your attitude a little draining.
You should be placed on a charge.
I'm sorry I'm a bit charged up at the moment I was a bit negative with that post I'm usually a neutral person but I positively know that farmer is talking complete and utter tripe. It's shocking!!!
