Known td5s to be retro fitted with 300tdi lumps !
Horses for courses you love em or hate them and there are more "experts" out there than you can shake sticks at I know what I know and when I dont know it I ask ! Can't say fairer than that :)
Hi mate would be better to fit a better engine or a 200tdi thanks Jon
  • Replies 31
If it was me I'd stay with a good 300. 200s parts are starting to dry up like I said above there are only second hand heads avaliable no new 200 heads ! Injectors are recon only for 200s now
John as I said in pm get it to someone with the know how and tools to check the block face and head for warping 300s have a nasty habit of warping the blocks of cooked up to much and as fat sad I know it writes the block off as it may not have enough material to alow for a trueing skim without affecting the piston to head clearance
Hi mate thanks for that Jon
HI WILLIAM we think it was ONLY LOW ON WATER thanks jon :thumbup:
I think it'll be worth keeping a regular close check on that Jon.... the water must be going somewhere!
HI STEVE thats what we are doing mate we think it may be radiator thanks jon :thumbup:
If it's leaking them it's going to probably be the P gasket on the front of the block behind the alternator and powers tearing bracket or the rad or one of the hoses Google p gasket 300tdi very common make sure you get it done with using the metal type genuine gasket
