Stihl
Anton
if the holes line up you should be able to run the bar but you would need to buy a .325 sprocket for the 361.
Really? i thought nearly all stihls had 3/8's drive links, other than the big brutes, all my stuff is 3/8s. i would have thought they would both be the same? thought it was only husky/dolmar/etc that used .325 as standard.
but i may be wrong,
bizare,
just checked their website... how come stihls mid range saws swap from 3/8lp to .325 then back to 3/8 again? thats just silly, as its small <50cc huskys running .325, then everything else is on 3/8's
seems odd to have a few midrange saws running .325 when they could easily pull a 3/8s Chain?
