  • Replies 46
Thanks for that
The advice on here is great, installs a bit of confidence
Have done I bit of climbing since my 38, but not to much spiking
So all advice is very much appreciated
If you're doing a tall tree you'll need your main line up with you for lowering the saw down to your groundie to refill. I use my lanyard connected to my side rings as my main attachment to the trunk and my climbing line connected to my bridge as the back up.
So what's the protocol here for if you're on a stem, with your lanyard round the trunk, and your main line underneath, and you do yourself a mischief and need to bail fast?
My options are pulleysaver, fig8 softlocked on a single line, or buy a wrench just for that scenario.
I reckon you should always have a quick descent option for if you need it, but how many others dont have one on a chog down?
gaff out slide down stem using nose as a brake.
or alternatively bail out on main line through pulleysaver choked around stem.
