I'm looking for someone with a top notch Excavator based Skyline setup for an unusual project I'm pricing.
Ideally 20 tonne plus base unit, as the main factor is the fully suspended load it can handle safely.
This will be a very strict job in terms of safety etc and the need to keep downtime to minimum, hence wanting someone running a really nice tidy unit.
The project will hopefully be mid summer, which will hopefully be a quieter time of interest for someone to bring one out of the woods for.
The project is in North Staffordshire, but obviously such a unit is going to be from further afield, and should be around two weeks duration.
Any recommendations/contacts much appreciated.
Eddie.
Ahh, shame you are so far away, I was working alongside a brilliant outfit the other day, remote controlled winch mounted up on the top of the boom of a 13 ton Doosan. pulling trees up an over a steep bank, never seen a setup like it but really was the tool for for this particular job. perhaps a bit small for what your after though...
Was that Will Kingwell?
I know couple working Central Scotland but you're obviously bit far away. If struggling to find anyone you could try contacting A&B Services, Killin as they build them and may know of one local to you
Speak to the commission Eddie as they have one coming into the churnet again shortly. I will send you the contact number of the chap to speak to
Eddie.
Hi EDDIE JOY OFF HERE HAS ONE mate thanks Jon
