The ram that activates the trailer brake on my indespension plant trailer has got a bit of play in it through wear and tear, is there bushes bearings inside that can be replaced? or do you have to but the whole lot?
When you say a bit how much movement does it have?
It's not dangerously bad, only a couple of mil, I wanna rectify if before it worsens. Don't really want to buy a new one as they cost a fortune!
Are you referring to vertical movement when in the normal rest position or horizontal movement as it slides in and out ?
Yes vertical. When it is off the van I can move it up and down, but no play left to right.
