I agree and know all that . I have been reporting them for at least 4 years on fleabay but have given up now . Seen the " 365 " ones bid up for stupid money . Obviously by people not as knowledgeable as you or I . If it says mix ar 25:1 then no need to look any further . Its a fake .
True - but far from all ads include such specs.
What you put together for your own use is nobodys business - but never present the result as the real thing.
It will be heavier, and of sub-standard quality - there is no way around that!
....and of course you will be supporting the cheaters.... :cursing:
Heavier? I agree with sub standard, but that is because there is no quality control. I've used Chinese parts, a lot of the time, making modifications wouldn't be possible if I were buying oem parts, and full rebuilds would cost too much
  • 4 years later...
 Its becoming harder and harder to tell as the clones become more and more accurate .  If it says run on 25:1 then its a fake . If not I would say its genuine .  If it is a real Husqvarna the 365 special will have a 372 bottom end making it a bomb proof belt and braces under stressed , go on for ever saw .
The serial tag and box look genuine to me. Give me a minute and I would be able to tell straight away if it was in front of me.
Turkish by any chance?
The fake I saw had a super stiff recoil, the rubber pipes were soft and moulded with a flash mark down both sides and not like normal Husqvarna kit. Look for Mahle on the cylinder, A or B on the little flat by the spark plug and the usual moulded date codes and part codes on the different covers - if you are not sure!
1 hour ago, rolsstar said:
hi guys, is my saw original or fake?
Where did you buy it?
2 hours ago, Stubby said:
 Klonlar gittikçe daha doğru hale geldiğinde bunu söylemek zorlaşıyor. 25: 1 üzerinde çalıştırmak diyorsa o zaman bu sahte. Değilse onun gerçek söyleyebilirim. Gerçek bir Husqvarna ise, 365 özel 372 alt uca sahip olacak ve bomba geçirmez bir kemer ve stres altında parantez olacak, hiç gördüm için devam edin.
What do you mean by 25: 1 ?
1 saat önce, spudulike dedi:
Seri etiket ve kutu benim için
Seri etiket ve kutu benim için gerçek çalışır. Bana bir dakika ver ve hemen önümde olup olmadığını söyleyebilirim.
Türkçe şans eseri?
Gördüğüm sahte süper sert bir geri tepmeye sahipti, lastik kullanan yumuşaktı ve normal Husqvarna kiti gibi değil, onu iki kez bir flaş işareti ile kalıplandı. Buji ile silindirde Mahle, küçük düzlükte A veya B'yi ve farklı kapaklardaki normal kalıplanmış tarih kodlarını ve parça kodlarını içerir - emin olun!
gerçek başlar. Bana bir dakika ver ve hemen önümde olup olmadığını söyleyebilirim.
Türkçe şans eseri?
I don't know which codes to look for
Edited by rolsstar
You know it's a 2 stroke engine ?
You better do a little bit of home work about the fuel and oil mixture required for 2 stroke engines. Maybe you have the owners manual with the saw,  time to have a read.
25:1 is the ratio of petrol to oil that a lot of chinese manufacturers recommend.
