  • Replies 34
That similar to the ezy rail system?
Same principle of bolting together bits of aluminium. In my case they are 5' lengths of 6"x2", with an internal clamping system. It is very compact and extremely rigid. I have four lengths so can do 20'.
Alec
I use a couple of planks, each 6" x 1 3/4" x 9'. simply build a bridge using these planks to the height and length you need and then slide the ladder along as you mill. remember to pack under the planks to stop sag and vibration.
I bought a 6m long ladder last year for about £100 online. I had alot of 6m plus oak beams to do at 8"x8" for a new barn. I just couldn't get a true beam moving a ladder, or using 2, but maybe that was just me.
I kinda needed a 6m ladder to work on the barn anyway, so two birds with one stone!
  • 2 months later...
  • 1 year later...
Easiest way to cut an 18ft beam with an Alaskan is to take it to someone with a bandmill and get them to do it. Given that Alaskan milling is manual, and board handling is usually manual, do you really want to have to lift an 18ft beam? It could take all morning to square up a log with an Alaskan (especially if there are a few boards from the outside of the log) and that same log could be done in 15 minutes on a Woodmizer or something similar.
An Alaskan is an invaluable tool for certain applications (wide boards, inaccessible timber) but it's not suited to producing dimensioned timber.
Good point
Unfortunately, without some serious heavy duty lifting/ winching equipment a 6m length of 32" diameter (or wider) lump of oak ain't coming out of our woods.
Will be easier and less destructive to habitat if it's cut into more manageable sections (with an Alaskan).
Cheers, steve
We are very close now to producing our own first cut system... very close!
It will come in 1.5m lengths (with an option of 3m lengths if you are mainland UK) and should be very easy to clip together.
Will have several options as how you fix to the log.
Will be cheaper and better than the current EZ rail system (for a basic 3m system that does not join together ie comes as 3m lengths rather than 1.5m) price will be around the £180-00+vat.
Not quite £7-00 ;) but I think folk will be happy with what they get.
:001_smile:
