  • Replies 47
  martyn1 said:
lucky!
I would have put a bigger mouth on it .... more control in direction of fell.
Thats the one!!! NO NOTCH = NO DIRECTION!!!:sneaky2::001_tongue:
One trick I have used a few times is if you have an anchor point in line with the hinge some distance away is put in a lowering rope as high as you can down to the anchor point and put a bit of tension on. Then when you fell the rope follows the same pivot as the hinge but the tip of the stem cannot move towrd the fence.
Luckly judged!!
Hopefully we are all moving from less luck -----to more judgment .
Great to see the vid and the analysis. A bit like a good debrief.
With a fence so close a stay rope( 90 degrees fall direction) to plus a pull rope would have been ideal.
A deeper face cut(gob) with the direction slightly more away from parallel to the fence line.
We would have had wedges in the back cut nearest to fence side.But i drum it into my guys to always have axe and wedges with them when falling.
Awesome that their are so many experts in one room:001_tongue:
  old snake said:
Cheers guys i hear wot your sayin about a bigger gob but there was a great big hole in one side of the tree and i wanted to try and leave as much sound wood as possible to use for the hinge. I like the idea of usin the butress roots to hold it though steve.
Here's a pic of the stump
Was that a back release cut? and are those your wedges in the top left hand corner?
Read more
