Stump grinder sharpening
colwoodlandcare
So I've been using a dimand disc on the grinder for a while which does the job ok although not the fastest it's good for on site touching up.
I've just purchased a 8" wetstone bench grinder and need to buy a decent wheel for doing the stump grinder teeth.
I've heard green wheels, can any one recommend a good 8" one?
Sent using Arbtalk Mobile App
http://Www.colwoodlandcare.co.uk
Hi
I think we have Green wheels in stock at our Haywards Heath depot, will have a look and give you a call tomorrow.
I need to find a new system for the sc252, wondering which is cheaper?
New multi tip wheel etc? Or if std wheel will accept pockets and green teeth?
Dont know how to sharpen ginder teeth yet, use multi tip on other machine then when blunt throw in scrap
Rather than cheaper why not get what's better, cheap very rarely is best in my experience.
Its not neccessarily cheaper that im after, maybe worded wrong.
But it will be 400 for multi tip wheel and i do like them
Or it may be 250 for pockets and green teeth which is appealing, but i may be able to sharpen these myself or get sharpened local which would steal the deal for me
the green teeth are a doodle to sharpen and they should fit straight onto a cutter wheel that has been fitted with finger teeth make sure you go for genuine green teeth as some of the other ones that you get will fit but the heads are a smaller did and it causes the nose of the shank to wear thin .on our grinder which is only 28 hp we reduced it down to 4 pairs of shanks set with 2 straight then two angled at opposite sides for balance and it cuts very well
I used to sharpen my multi tip teeth no problem.
Not sure if you can get 8", we have stocked 4" green wheels.
