Hi have a Tp 150 chipper which chips really well until i do leyandi , after about an hr it blocks the shoot , i clean her out but 10 mins later she does the same . on any other stuff shes fine any ideas why or how to stop it ? i have tried putting less in at this rate its easier to to chuck it on van and dump it
Blades are sharp , the chip size is constant . just seems to block the shute at the base i clean her out and run bare wood through her and its fine as soon as i put leyandi through her again like i said afte about 10 mins shes blocked .
i know a guy who cut the bottom off his chute so that green material could just fall out before blocking the chipper, 190 timber wolf i use blocks if nossle on chute is aimed down too far.
