Td5 defender brake fade
Pinkfoot
Have you noticed if there is a small drip below the brake pedal? Not the easiest thing to notice if your landy is as dirty as mine. I had the same problem with mine and it turned out to be the master cylinder leaking. Its only a small leak so hard to notice, just clean the floor below the pedal and check it after a day or two's use. Its a very common problem. Not hard to fix and parts are cheap, just fiddly to do.
When the engines running the servo gives more power to the brakes . If the pads are seized they flex more in the caliper giving a softer pedal .
Servos don't give brakes more power they just make the pedal easier to press. If it's still a good pedal with the engine off after two or three presses to exhaust the servo it sounds like it could be a servo fault. Check for split pipes.
Pop round yer local garage and ask what a servo does , also known as a brake booster to boost pressure . :001_smile:
