collar the roof new joists for floor kingspan between rafters bespoke staircase hung on structural Joist £32 K is outrageous unless you live in a palace! 12-17K should cover most.
All depends on the size of the loft conversion we did one 10 years ago by a specialist company Trussed Loft Conversions 25k gained 2 big bedrooms saved moving and all costs involved which now mount up .
  • Replies 27
My son has just done a loft conversion so this is going on the bits I can remember as I was not involved too much.
Joists need to be 200 mm x 50 mm at 400 mm centres.
Velux is ok for fire escape,but has to be fixed no higher than 1 m at lowest point.
Fire door has to be fitted at top of staircase.
planning was not needed but building inspector has called on regular basis.
