hi guys last week i noticed that the bottom roler on my chipper looked like it had dropped on the right hand side, i have so far got the hopper off and taken the hydrolic moter off of the bottom feed roler etc etc but i can not work out how to get the bearing off of the hydraulic pump side of the reed roler , can any one shed any light on how to get the feed roler out and change the bearing ????
i woulkd look at the owners manual but that was lent to a fellow tree surgeon and never seen it again , i would be really greatfull for your help guys
many thanks Dave .
I think this has come up before on here, and most ended going main dealer to get it sorted i ma sorry to say. It seems that bearings on tw's are a bit of a prob. You chipperless until it is fixed?
i think i am going to have to hire one in sadly as we have to clear up a call out tomorrow :mad1: with a bit of luck i shoud be able to get it fixed for tues if i can order the parts tomorrow . The gutting thin is that i have got to the bearing but can not see a way of getting it out without the use of my air chisel ha ha :confused1:
Ah.......
Good luck mate.:001_smile:
i woulkd look at the owners manual but that was lent to a fellow tree surgeon and never seen it again , .
Is that the same guy that has your pic's???:sneaky2:
Timberwolf - Arbtalk.co.uk | Discussion Forum for Arborists
try asking the timberwolf man
thats what steve set this up for i think although may not work on a sunday
post a pic and will see what we recon
thanks bob i didnt realise there was such a think but i have posted a thread so with a bit of luck i will be able to get it fixed . many thanks again :001_smile:
timberwolf will receive a notification of that thread you started, so hopefully it should get answered fairly early on tomorrow......yours will be the tester!!!
im sure it will work fine steve , great idea by the way , have you got something similar for getting picture out of groundsmen ha ha :001_tt1:
Oh- an off the top of my head, if the bearings have a collar retaining them, undo the allen screw retaining them an tap them off by tapping them clockwise or anti clockwise as they are cam-ed on. This applies to lots of rotor bearings too.
K
