Rakers or cutters
50 members have voted
  1. 1. Rakers or cutters
    • Cutters First
      46
    • Rakers First
      4
Following on from the thread about sharpening new chains, i wondered who sharpens the cutters before checking/filing the rakers, and vice versa?
  • Replies 27
always cutter tom, them the rakers. i need to know how much i have taken off, never use a depth guage though, doesnt seem to take enough off. then when you use it again you know how well you did, fine dust=not enough. over the handlebars=too much,cutting butter=just right
swb place your flat file in line with the run off the chain across 3/4 cutters & you can see the gap ,reduce as required :001_smile:
Should always sharpen first!
The idea of the rakers is to give a set depth of cut, and whenever you file back cutters, because of the lowering slope of the cutter, you adjust the depth of cut. The cutters should be sharpened, then the rakers re-set.
Therefore setting depth guage prior to sharpening is putting cart before horse!
Cutters first always for me for best results, depth gauges are important the reduce vibration stress on the saw and i reckon increase chain life, so its important to do the cutters first to get the depth gauges right. I do all my sharpening by eye no gauges, apart from using the depth gauge to check i'm right, not use it as a filing guide!
not @ all you should be able to judge what needs taking off after a lot off yrs you will find it come on its own :001_smile:
