If the chain is bouncing and producing a small amount of dust for a lot of personal effort, you've got the chain on backwards.
If its on backwards just stand the other side of the log :biggrin:
No, that won't work, you have to turn the saw upsidedown 😁😁
... As Eddie said, it is like milling!
Yep. Basically you're ripping the log. Near enough nipping off the tops of the fibres. And ripping with a cross-cut chain is going to be hard going on the saw. Even if the chain is sharp, you'll only ever get sawdust. For noodles as has been said, the cutters need extended contact with the fibres along their length.
