Quite a long video but skip the 1st 3.3min to avoid me wittering on about stuff to where the real work starts.
Got a bit of hydraulic help from lunchtime on for a few hrs to make sure the job was done in a day.
Hope you enjoy.
BACKBONE TREE RIGGING:
  • Replies 37
Just a naughty tight spot where it was growing and not 1 bit of damage.
Spot all the orange dots on the 1st 6ft of trunk.... Nails, over 25 just on the surface alone,hit 1 strate off with the 088 on the last cut then 4 more before finishing the cut :-(
Just did turn wet at the end of the day as well which didn't help.
Always when you've got a new chain on aswell :mad: think the last bit will become habitat somewhere eventually ;)
Enjoyed it as also always like a dismantle that takes a bit more thinking about.
Used the backbone on almost every job since, so easy and the groundsmen love how quickly they can get it off and back to me, added bonus is that because it's quite heavy it won't just disappear back to the pully if you accidentally let go.
Yeah as we know its not a five minute job getting big saw back sharp ha! Also Clove hitch, timber hitch can get trapped under big lumps of timber so groundsman struggle to un- do. If it works mate for you and ground staff spot on efficiency is the game. I'm section felling 4x sycamore on monday i will be setting up using a controlled zip. I reckon the backbone can be incorporated into that set up..cheers
If a sling is trapped just leave it till you can cut it free or help to lift the section is available but you can get the main rope back to the climber to ready the next bit which is where it's easy to loose time.
Don't tend to do many controlled zip lines, plenty of speed lines on light stuff but nothing on bigger timber.
Enjoy and try get a few pictures if you can :thumbup:
Read more
