No games. Please remeber that you are speaking to one of technology's most inept!:biggrin:
If I'm reading you correctly, it's 16gb, 12.3gb are used and the update is 1.3gb.
Hi EGGS SORRY that's not right thanks Jon
  • Replies 33
Settings, general, usage, manage storage. What on the list is using the most eggs?
Btw I know bu€€er all about them. Only got this one last month!!
Google was a big user, so was documents. Moved the docs, still can't sort the bugger out.:thumbdown:
Of the stated 16GB, 3.2GB is taken up with the OS and Apple's bundled apps. Leaving you with 12.8GB useable storage. So if you've used 12.3GB and the update is 1.3GB, then you'll come up 0.8GB short.
So even if you're able to free up the required 0.8GB. It still leaves you with the problem... zero storage space. You either have to choose which apps you really need and what you keep on the pad, rather than transferring to your PC, (if you have one). Or you get a pad with greater overall storage - 32GB or 64GB.
Also, have a gander through here:
http://support.apple.com/en-gb/HT201656
and here:
http://m.wikihow.com/Manage-the-Storage-on-Your-iPad
Edited by TGB
So even if you're able to free up the required 0.8GB. It still leaves you with the problem... zero storage space. You either have to choose with apps you really need and what you keep on the pad, rather than transferring to your PC, )if you have one). Or you get a pad with greater overall storage - 32GB or 64GB.
See how much storage you've used on your iPhone, iPad, and iPod touch - Apple Support
Hi mate that's what I'm doing on my next iphone 64gb thanks Jon
Its worse than that, the update requires 5gb free space to install. Had the same issue here, ended up deleting a few apps and rei stalling after the install
Hi mate I had the same on my iPhone i had loads of apps not now thanks Jon
That the way apple decided to do it, system update wouldn't even download with there being 5gb available on the devise.
Glad its the other halves ipad, my android tab did a system update the day before with no hassle or drama. Just apple being difficult
