Done a 394 last year then a 660 this year when they ran dry due to the 661 recall.
Both run as they should and par equal with factory built. (no reason why they shouldn't)
It is however an expensive way of doing it even importing quite a bit from the states and avoiding duty.
Done many, the funniest was a MS390 that came in as a box of bits from a guy in the IOM.
Β
I rebuilt it and had some strange plastic parts left over, I described them to him and it transpired he was a little inebriated when he took it apart hence the lack of abillity to fix it.
Β
The parts - they were off his Toyota Hi Lux and had wondered where they had gone:001_rolleyes::lol:
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
