Hilux oil leaks 😂
div_h
Anyone had any experience of changing the sump on a Hilux? I'm in the middle doing one... Its a 3.0ltr diesel 2008.. Just wondering how you or how much it cost to get done? The one I'm on is my bosses so it's not really costing him as he owns the garage 👎
  • Replies 20
Id imagine youll need to remove the diff, the drives and loosen the engine mounts and lift the engine a fraction... clean the sump strainer as they can give bother. Possibly do injector seat seals.... worth posting in hpoc forum, decent folks. The sump may have bolts covered by the gearbox, that can be a pain
Tryed lifting it up of the mounts- no use:thumbdown: only lifted it up an inch and a half gearbox holding it down. And it's an automatic as well, cooler pipes run along the o/s of the engine to the front and into the radiator.
So I've got it in this state :biggrin:
[ATTACH]169659[/ATTACH]
oh feck that!! for the sump?? thought it would be tight but not that bad!
